주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
No service (GSM signal: 3G/4G and SMS but wifi works fine)
Hi !
I hope you’re all doing good :)
I recently changed the screen and the battery of my Iphone 6. Everything was working just fine for a week until yesterday. I can neither receiver / send SMS, nor access 3G/4G.
J'ai démonté et remonté l'écran et la batterie
  • I disassembled and reassembled the screen, the battery and the coax connexion
  • I restored the phone and the carrier parameters
  • The IMEI is still running
  • The SIM card works on other phones
  • I downloaded the last IOS and Itunes version
What should I do ?
Could it be a motherboard issue or a welding issue ?
Would it be worth trying to replace the lightening dock ?
Thanks in advance for your help !
Margaux
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Is the IMEI showing also when dialing *#06# or just in the phone info ? If it does it shouldn’t be the baseband IC issue many iPhone 6 show when the logic board was flexed or badly hit. If you get IMEI when dialing it might be worth trying replacing the dock to not let anything untried, but it might nonetheless be a logic board issue
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Try replacing the charging port flex otherwise cellular data is turn off.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
margox 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 5
전체 시간: 65
