주요 콘텐츠로 건너뛰기
MacBook Air 11"의 2015년 3월 업데이트는 5 세대 Intel Core i5 및 i7 프로세서를 장착하고 배터리 성능이 약간 향상되었습니다.
141 질문 전체 보기
Where to get high-temperature foam?
I replaced the battery on a Macbook Air, and the battery connector keeps coming loose. I think that the best solution would be to tape a piece of foam on top of the connector, so that when the Macbook is reassembled the connector is pressed into place by the bottom cover. I am worried about the temperature, so I am reluctant to put on just any piece of foam. Does anyone know where to get high-temperature foam, especially pieces that have adhesive backing?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Just use a piece of Kapton (Polyimide tape ) tape on it
Polyimide Tape
Kapton is a polyimide film developed by DuPont in the late 1960s that remains stable across a wide range of temperatures, from −269 to +400 °C. Kapton is used in, among other things, flexible printed circuits and thermal blankets used on spacecraft, satellites, and various space instruments.
Polyimide Tape 이미지
상품
Polyimide Tape
$9.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thank you for the suggestion. I have ordered that and plan to use it. Maybe that is all that I really need. However, I was hoping to get, in addition to that, some foam to provide additional hold-down or press-down force. I know it must exist, because there are pieces of foam inside of the Macbook, on SSD drives, etc. If you or anyone else can suggest a high-temperature foam product I would be grateful.
댓글 달기
귀하의 답변을 추가하세요
Tom 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 7
전체 시간: 87
