주요 콘텐츠로 건너뛰기
Mac mini가 오랜 기다림 끝에 새로워졌습니다. 프로세서 옵션에는 3.6 GHz quad-core Intel Core i3, 3.0 GHz 6-core Intel Core i5 및 3.2GHz 6-core Intel Core i7 프로세서가 있습니다.
Solder an external power button to the latest mini?
Hi y’all,
Just got the latest Mac mini and I need to add an external power button to it with long wires so I can turn it on and off from a distance. In the previous models I was always able to trace back the wires to the pins and splice the cables but with this ultra flat cable now, anyone knows where I need to add my wires?
Thanks a bunch!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 3개
선택된 해법
If you are trying to setup a media server (or other server) you can setup wake on LAN which is what I would do.
이 답변이 도움이 되었나요?
점수 3
댓글 12개:
Thank you @danj , I think I figured it out and I’ll post my result on this forum cause, hey, might be useful for others. This year’s Mac mini’s layout makes it difficult to figure out which pins are the button ones because of the 8-pin flat cable. But I think I found them. I’ll try to turn it on and let you know hehe
Do keep in mind if you alter the logic board or cable connection you will void your warranty!
@danj did they get rid of the IR control?
@mayer yes, they ditched the IR control. There is no more black piece of plastic under the sleep light which is where the IR sensor used to be.
Sadly, I don't see any sensor window in the IFIXT teardown. Bluetooth or WiFi would be the only way you might be able to turn it on remotely wirelessly. I have mine (2011) setup to wake on LAN.
댓글 7개 더보기
댓글 달기
So what was the solution? You wanted to post it…
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I’d love to know how to bypass the switch I broke mine. I juts need to get it turned on !
I also want to know this solution.
댓글 달기
I created a Mac Mini M1/M2 Holder Vesa Mount with Switchbot and Servo Power Button Pusher you can print to use for this. https://makerworld.com/en/models/1637923
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jess B 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 40
전체 시간: 2,494
