Oil leak from exhaust
== Oil blowing from exhaust muffler .runs well and starts ok.this problem seemed to start after fitting new drive belt.many thanks.a ==
좋은 질문 입니까?
좋은 질문 입니까?
Oil can seep into the exhaust system if the piston rings are worn or if you turn the engine on its side. The oil that gets into the pistons is pushed out without burning. If the liquid coming out of your engine is slick and smells more like oil, suspect one of these two causes.
해당 답변은 도움이 되었습니까?
This could be the solution to the problem when the oil gradually starts leaking past the rings over a period of months, or years - BUT Briggs (and some other engines have a problem with the engine running basically with no smoke 1 day and then blowing smoke and oil out of the exhaust the next day - it has to do with the pulsation system which powers the fuel pump
24 시간 전: 3
7일 전: 19
30일 전: 100
전체 시간: 4,882
