주요 콘텐츠로 건너뛰기
Galaxy S7 Edge는 Samsung의 2016년 주력 휴대폰 Galaxy S7의 곡선형-스크린 버전입니다. 2016년 2월에 발표되었으며 3월 11일에 출시되었습니다. 모델 SM-G935.
369 질문 전체 보기
My phone is flickering and has a black spot. what should I do?
My phone started flickering one week after i dropped it but it worked fine until after two months it suddenly stopped and a black spot came and the screen start flickering and would only stay on for a few seconds. i am still able to unlock it and swipe down the home bar. I have not dropped it ever since the initial drop. what should i do? should i buy a lcd screen or lcd digitizer?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
The screen needs to be completely replaced as a assembly.
LCD digitizer sounds like just the glass with the touch screen layer, this is only useful if you are replacing just the glass while the display is not damaged as a professional refurbisher.
LCD screen is what you need as both layers are damaged, I'll link you the replacement part and guide so you know what I am referring to:
Galaxy S7 Edge Screen
The replacement screen is fairly pricey so I recommend looking around locally in your area for anyone that does screen replacement on the S7 Edge.
Galaxy S7 Edge Screen 이미지
상품
$159.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Pheew..that's an arm and a leg..and they say Apple is expensive =')
댓글 달기
귀하의 답변을 추가하세요
Antony Antony 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 11
전체 시간: 1,614
