주요 콘텐츠로 건너뛰기
{A1706 / EMC3214}—2018년 7월 출시, 이 MacBook Pro 13”는 쿼드-코어 i5 및 i7 프로세서 그리고 Intel Iris Plus 통합 그래픽 포함.
199 질문 전체 보기
Why I cant connect to external display?
Hello,
I have this problem at my work with my MacBook Pro 2018.
While connecting to projector with 15m HDMI cable via USB-C hub I get no input on projector, but my Mac finds the projector and I can even change resolution of projector.
Then when I took a shorter cable my Mac suddenly started to mirror display. All windows laptops works perfectly with that projector and most Mac’s do as well.
Tried different USB-Chubs no help, and I had same problem with two different Projectors and two different MacBook Pro’s both the newer 2018 model.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
After booting completely and with the external plugged in hit Command and F1 keys at the same time.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Will try it next time I come across Mac
댓글 달기
I don't have the latest mac, but sometimes they don’t get connected automatically to an external display. If that happen, you should check the section of displays in settings, and select it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Artur Aleksandrov 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 10
전체 시간: 107
