주요 콘텐츠로 건너뛰기
다양한 옛 스타일 게임 시스템 수리 정보.
106 질문 전체 보기
Why does my NES display a solid pink when it is turned on?
When I start up my NES system every time, it displays a solid pink. Does anyone know why it displays pink? The pink screen is annoying me. I've already tried using my air pump to try to get dust out of the console and also I keep trying to reset the console.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
If you insert your game, and the screen is pink or any other color. Follow these steps to the letter.1. Blow into your game cartridge, and NES system slot with a dry mouth. Slide your game in. 3. Start pressing the reset button,but at the same time push down your game. I had this exact same problem, and solution. Hope this helps
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
thank you so much. i got my tetris working because of you.
댓글 달기
NES pin connecter compatability
Clean the 72 pin connector, this should help.  You may also need to clean the cartridge connector if it is isolated to the one cartridge.  Alternatively replace the 72 pin connector (ebay).  I recommend cleaning first to save cash.
Update (11/16/2018)
Why won't the screen and red light stopping blinking?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I tried cleaning it numerous times now (just now got the stuff to clean the NES so that's why I'm replying just now), however the only game it worked with 100% (no glitches or magenta screen) is Super Mario Bros/Duck Hunt. Before I buy a 72 pin connector, would you suggest other solutions or possible problems?
댓글 달기
귀하의 답변을 추가하세요
Aiden 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 6
7일 전: 16
30일 전: 91
전체 시간: 5,523
