주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
Added a 2nd ssd in optical bay-how do I use it as a separate MacBook?
I have a few questions related to this actually:
  1. When I turn on my computer ever since I added the 2nd ssd in place of the optical drive, the computer gives off this loud fan sound for a few min, and then continues more softly
  2. I cannot add or remove files in the 2nd ssd without having to enter my macbook password
  3. Is there any way I can use this second hard drive as a separate system altogether?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
It sounds like you transferred the drive from another system to this system. If that is the case you’ll need to correct the permissions of the drive by adding your user account to the other drive.
Click your systems primary drive from the desktop (having drives visible on the desktop) go to the Users and your active user folder with it selected. right click and select ‘Get Info’ that will allow you to see the permissions at the bottom under the twisty ‘Sharing & Permissions’ You should see your user account, now click on your second drive you likely won’t see your account listed this is where you need to add it. If you have multiple user folders on the second drive you’ll want to select the folder you want your user to have access and then alter it Vs the full drive.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
  1. Does it start like normal? No delays or anything
  2. thats a security issue. I have the same Macbook. I will check it and let you know. (How did you format the second ssd?
  3. You mean dual boot. So when you start you want a screen where you can choose from what SSD you want to run MacOS. Both MacOS ?
kind Regards
Brenda
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Zoon Staffing 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 35
