주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
Computer still running everything else without power
So good Day,
Today i had a Random Encounter while playing.
My Monitors went black Sound cut Mouse and Keyboard were without power aswell, but the pc Didnt turned of by Holding the powre buttom or pressing Restart.
Windows Event Log didnt gave any clue after unplugging.
Specs:
Ryzen 7 1800X ( Auto OC)
KFA 2 GTX 1070 EX
16GB G.Skill Aegis 3000 MHz CL 16-18-18-38
Corsair VS550 550 Watt
MSI b450-a pro
Kingston 120GB, Crucial MX500 500gb SSD
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
hm Stress Test was Fine had it sit for 1:30hr.
psu should be fine worked before with a i7 on it without an probs OC aswell.
but yet didnt happend again.
maybe just a hiccup of the different sutff that ran the same time was a ba combi.
4 Anti hacks of different games sometimes arent a good mix lol
I'd still probably look at upgrading to at least a 650. Just a cursory entry of your specs in the calculator put you at 560 and change watts. Personally, I would rather be on the high side than risk under-powering my CPU and causing other issues. YMMV though, good luck!
댓글 달기
답변 3개
가장 유용한 답변
That power supply is right on the verge of being too small for your setup. I would look to upgrade it or you will probably continue to have problems.
You can check your power requirements with online calculator tools like this:
https://images10.newegg.com/BizIntell/to...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hello, try to run a stress test for your components to figure which one is damaged.
I’ll suggest to use Aida64, you can download it here
After you install it, go to tools and click on System Stability Test
Choose one or more tests, click on start and keep your eyes on the temperatures.
if nothing happened, then verify your psu cables and make sure that you plugged them well on all of your components.
Good luck :).
이 답변이 도움이 되었나요?
점수 1
댓글 달기
so ,
Finally i found the problem the PSU was Faultie.
replacement is on the way.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dennis Filbrandt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 78
