주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
iPhone 6s gets hot in standby and drains battery
Hello,
I have an iPhone 6s which is always warm when not completely turned off (even after multiple reinstalls via iTunes) so the battery empties after 5-6 hours in standby.
Besides that the battery actually is pretty weak, the phone gets warm at a specific spot, which is beneath the mainboard protection plate below the display connectors. Since I don’t want to risk destroying the mainboard with desoldering the plates, I wanted to ask if this is a common problem/spot and if changing the battery could even be the solution of this problem? If not, it would be nice if someone could give me an advice which chip or part is possibly causing the warming of the device. I am asking because I don’t want to throw more money at this phone when it isn’t solving anything, so please excuse me if similar topics have already been published, I just haven’t red exactly my problem so far.
Thank you very much for your help
Update (22.11.2018)
Hi,
thanks for all of your help.
I've made some further investigations and found out that the Home Button (not the Home Button extension cable) is guilty. Does anybody know if there are any Home Button relatable components beneath the protection shield over the sim card tray? Or is the warming even possibly caused by the Home Button itself? Unfortunately I have no way to test this right now and before buying a new Home Button I wanted to ask if it would make any sense.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
When there’s excessive heat and battery drains fast you have a short to ground that drives current where it shouldn’t go. Right below the connectors the shield covers the Cpu but also a number of other capacitors and screen drivers.
I’d try running the phone without display connected to understand if screen is causing some issue..if excessive heat disappears it might be you have a short caused by the screen and a replacement should be considered..did it get hit badly at some point ? If you still got overheating without screen attached, in the same area, unless you’re a technician there’s not much you may achieve by removing that shield except damaging the phone beyond repair.
해당 답변은 도움이 되었습니까?
점수 6
댓글 5개:
Usually on the 6s it's drop damage where the wifi chip gets shorted but still works.
I don't really bother with these for board repairs as it ends up either costing too much or ends up being a rabbit hole.
@benjamen50 I don't like wifi chips reworks either, especially the bigger ones of iPads, yuck..
Hello again, I disassembled the LCD and the phone was cool again, so it seems the fault has to do something with the display. Is it possible that the display is defective or is it more likely something on the iPhone logic board?
Thanks in advance.
@danm270 I'd definitely try with another screen, if it has taken hits or if it's an aftermarket screen you have just installed, chances it may be causing the issue are there. The alternative is to pay a repair shop and let them do the testing..choice is yours.
Hi,
댓글 달기
귀하의 답변을 추가하세요
Daniel M 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 24
전체 시간: 1,924
