service light comes on and displays error code F08
error code F08 indicates a heater fault so I have replaced the element but still displays error code.
좋은 질문 입니까?
좋은 질문 입니까?
hello Simon this is the error code check the listed items from this error code.
The main control unit in the washing machine has detected that there is an open circuit somewhere in the heating circuit.
The main control unit will detect this error at the start of a program and during the spin phase.
해당 답변은 도움이 되었습니까?
In order to remove the error code: 2 options:
1 Reprogram the CCU which is known as an ETNA CCU (module). This will require a hardware key and an ESAM unit (neither of which are readily available to purchase).
2 Install a pre-programmed ETNA CCU for the correct model.
I’m adding this info in 2021 in order to help anyone who encounters the same problem.
BTW - I’m a field service engineer.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 11
30일 전: 46
전체 시간: 4,202
댓글 3개
are you getting this on a washer or dryer. Please give us your model number.
mayer 의
hello Simon, this is the error code and listed are items to check with that error code..
Whirlpool washing machine water heating element open circuit error F08
F08
Open circuit error detected on heating circuit
Check wash heating element for continuity
Check the wash heater for earth leakage
Check wiring to the heater
Check the control unit
twofast2trackpro 의
I have the same problem. After replacing the heating element, the code is still there. How to delete (remove) the f:08 code? Any ideas? The dashboard how to reset it?
Uran Malaj 의
