주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.3GHz, 2.6GHz, 또는 2.7GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.7GHz).
561 질문 전체 보기
Stuck on boot progress bar
Hi,
I have recently replaced the battery in my Macbook Pro . After the battery change I did a boot and the laptop was working fine. So I decided to change the thermal paste too due to the high idle temperatures.
After reapplying the thermal paste I can’t boot into the OS anymore.
When booting I am only presented with an Apple Logo and the progress bar. With a normal boot the progress bar will move to the middle of the apple logo.
In safe mode boot the progress will move up till 3/4 of the bar.
I have tried SMC, NVRAM, PRAM resets, and internet recovery. And nothing seems to be working :
Ran hardware check and there seem to be no errors
Running in Verbose mode it gets stuck on this line
I am currently downloading OS X Mountain Lion and will try boot from a USB. The mac was running on macOS Mojave before.
Any idea what is going on? Is there a chance of a messed up sensor on the motherboard :( ?
Any suggestion is appreciated :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Start up in Repair Mode and run Disk Utilities;
To use Recovery Mode, reboot or start your Mac and hold the Command and R keys simultaneously on your keyboard as soon as you hear the familiar startupchime. Keep holding as your Mac boots, which may take a few moments depending on its specific configuration.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
While trying to load into recovery mode the progress is still stuck. There are some purple bars running across the screen while trying to boot into recovery. I think there is something wrong with the GPU
Do you have the original hard drive? This is sounding like a problem present in the 13" machines. Please check to see exactly which machine you have. You can input the serial number from the back cover here: https://everymac.com/ultimate-mac-lookup...
댓글 달기
귀하의 답변을 추가하세요
De Siang Teoh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 7,285
