주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
465 질문 전체 보기
Fan running at full RPM
Hi Guys. My MacBook air 13” mid 2013 has a fan problem- it runs at max all the time. I have looked at the activity monitor- nothing unusual. I have tried all the resets- no change. I have tried some of the software for manually controlling the fan - no joy there either. I have replaced the fan - this solved the problem for a few days and now its back. Any ideas? I was next thinking of swapping out the logic board but this would be costly if it doesn’t solve the issue. Any help or advice is appreciated. Big thanks.
The battery runs perfect, no problems charging. No other issues. When I opened it to change the fan no obvious signs of damage either.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개:
Lets get some deeper diagnostics here. install both of these CoconutBattery and TG Pro take a snap shot of the main window of each and post it here for us to see 기존 질문에 이미지 추가하기
You could download “Macs Fan Control” it works.
@Ashley Nixon - TG Pro is a better thermal monitoring and management app.
댓글 달기
답변 1개
You need to go in to the bios and set the fan speed down. if that does not work it could be a number of reasons.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
@confirmedmars4 - The system has thermal controls which adjust the fans speed automatically, so forcing it is not a good idea until you understand the root cause. Which is where I was going here.
댓글 달기
귀하의 답변을 추가하세요
jack fuller 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 112
