주요 콘텐츠로 건너뛰기
Surface Pro 태블릿의 4세대 버전입니다. 2015년 10월 26일에 출시되었습니다.
208 질문 전체 보기
Is there any possibility that a Surface 4 has Surface 5 LCD?
I have Surface Pro 4 (This is the gift I have received) I dropped it and broke the LCD.
I bought an LCD, for Surface Pro 4, to repair it, from eBay. I removed the broken LCD, but the new one did not match the original cable.
I searched for letters written on genuine LCD, the letters is LP123WQ1. When I searched I got it was for Surface Pro 5, 1796.
I don’t understand, because mine is written 1724, behind the back.
What should I do?
Why is there another version of LCD on my Surface Pro 4?
Can I fix it with LCD, bought eBay?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 3개
Can you post a set of pics one of your Surface Pro 4 an the Surface Pro 5 cable connections so we can see the differences.
I may have a similar problem! I have a surface pro 4 that was ordered on amazon. I have ordered a new lcd and digitizer and all matches but the cable connectors :( I have pictures but am not sure how to post them here.
댓글 달기
답변 4개
가장 유용한 답변
Here are the pictures of the differences on my old surface pro 4 and the new lcd that was ordered for the surface pro 4
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
hi sorry its late but there are 2 version of lcd’s on the pro 4. one is made by lg and has a fatter cable that resembles a pro 5 lcd flex and the other which is more common has the standard looking pro 4 lcd flex.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Might be a little late to the party, but yes this is a very real possibility. My Surface Pro 4 screen cracked and I ordered a replacement on Amazon. The screen I got had a fault so the seller send me a Pro 5 screen with an adapter cable. So yes, my surface Pro 4 has a Pro 5 screen with the corresponding adapter cable
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I realize this is an old thread but it's unanswered. The surface pro 4 uses the same screen as the surface pro 5 and 6 The cables are technically the same cable just a different shape. To use the surface pro 5 screen on a surface pro 4 you just need to get one of the new cables.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
min le 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 14
30일 전: 25
전체 시간: 1,043
