주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 3 월에 출시된 G6은 Android 7.0 기반 LG의 주력 핸드폰입니다. 이 기기는 모든 주요 무선 통신사에서 사용할 수 있습니다. 이 기기를 물리적으로 수리하면 방수 기능이 사라져 물에 취약할 수 있습니다.
Cannot open LG G6 back to replace battery
I am having trouble opening the back of my LG G6 phone to replace the battery. I bought the iFixit repair tools with the decice you heat in the microwave and place on top of the phone to loosen it up. I habe tried several times and still haben’t been able to get it to lift up. Any suggestions?
Thanks
Adam
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Something I do that you might try is use sturdy playing cards to try getting under the corners of the back glass (using a sliding motion along the edge of the glass) once you’ve heated the back glass of the phone (either with the iOpener or with a hairdryer/heatgun). Once you get a tiny bit under the glass, you can insert more cards under the glass and the already inserted card, then slowly go around the phone and cut the adhesive holding the back on. The phone should be hot enough that you can just barely touch/hold it, in my experience - make sure the glass is very heated, as the adhesive on there is quite strong and can cause the glass to break if you put too much lifting pressure on the glass before getting through all the adhesive. If you do it right, you can even keep the original adhesive intact.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Adam Pease 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 24
전체 시간: 268
