주요 콘텐츠로 건너뛰기
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 질문 전체 보기
How to check the disc drive is the original?
Hi guys!
Is anybody now how to check that my xbox one (not the S or X) has the original disc drive? I bought with error E100 and looks like the disc drive was opened up and maybe somebody didn’t swap the pcb. Everything else is ok in the xbox. :)
Thanks for any answer!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You can’t really do anything else other than check the make/model number of the disc drive to see if it matches the type of drive that should be in your console. To check this, grab the model number from the console and Google the type of drive it takes. It should tell you, and you would look on your actual disc drive to see if the model numbers match. Now if they did a PCB swap, there really isn’t a way to tell and model number matching the PCB with the disc drive isn’t very helpful if the previous owner swapped the drive. If they did a complete drive swap, there is no possible way to get your console working without the help of Microsoft. It comes down to a DVD key mismatch at that point, and since the Xbox One has not been exploited in any way, there is no way to check if you have the original PCB and or flash a new DVD key to the PCB to match the the drive and console again.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you! I can see now that there is no way to find out! :)
댓글 달기
귀하의 답변을 추가하세요
balaghe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 11
전체 시간: 1,546
