주요 콘텐츠로 건너뛰기
Repair Guides for Sony Laptops
415 질문 전체 보기
Keyboard not working - model SVF15N72PGB
Hi guys,
My Sony Vaio keyboard just suddenly stopped working. I have noticed an error code 10 on the synaptic smbus clickpad (unsure if this relates) I have tried:
  • Rebooting
  • System restore back to when it was working
  • Uninstalling driver and restarting
  • Resetting windows completely
  • Going into bios mode to reset the values, the keyboard works in bios mode
  • Completing all available updates
Model #SVF15N72PGB
I'm at a loss at how to fix this :(
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
First of all, check it works with an external USB keyboard. In the short term that might be your work-around.
I don’t see a disassembly guide or video for your particular model, but they’re all much the same. Take a look at a few for similar Sony models and you should be able to see how to remove the keyboard. Sometimes it’s secured by one or more screws screwed through from the underneath, and sometimes you might have to remove a bezel between the keyboard and the hinges. But if you’re lucky it may just be a case of releasing the clips along the the top (or the bottom) of the keyboard. You can then gently lift it and angle it either forwards or backwards in order to access the ribbon connector which connects it to the motherboard. You might just need to reseat the ribbon in that connector (check from the videos etc how to release the clamping bar - it’s delicate). Otherwise, having got that far, replacement of the keyboard is easy - they’re quite cheap. Just make sure you get one of the correct nationality and for your precise model of laptop. But - without wishing to discourage you - bear in mind that it might be a motherboard fault, which would be much harder to diagnose and fix.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
ajm.smith 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 44
