주요 콘텐츠로 건너뛰기
First-generation Apple iPad with 3G capabilities. Model Number A1337. Available with 16, 32, or 64 GB of storage. Repairs are straightforward and do not require heat.
20 질문 전체 보기
How to run iPad without battery?
I bought an iPad with dead battery (it’s bulged). When I connect it to a charger, the only result is a boot loop (Apple logo, blink, Apple logo, blink…).
I want to use it as a kind of picture frame, which would necessitate constant charging anyway, so I’m reluctant to buy a replacement battery that will be of no use and dead again within few months because of constant charging.
Is there any way to forgo battery entirely? Some “fake” battery to allow it to boot?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
iPad is designed to run with a battery, thus there’s no really easy solution for your need. Not sure if the system requires also a battery presence acknowledgement or it’s sufficient a component bridging, but unless you’re able to microsolder and have the necessary tools is not a very handy solution. If you have to find and pay someone doing the job you’d end up paying multiple batteries cost to get the job done. All in all I believe a battery replacement is the easiest and cheapest solution.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
Stan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 40
전체 시간: 8,262
