주요 콘텐츠로 건너뛰기
The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
159 질문 전체 보기
Hdmi port failing in Xbox one X
It works, sometimes, I have to tweak the cable to a certain angle for the connection to fully work. I just need help finding a quick tutorial on how to replace it or reseat it.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
The HDMi Port is soldered to the main board there is no easy fix for this unless you are able to solder, Have you tried another HDMI cable ?
If that dosnt’t work try cleaning the port with a cotton Bud and some rubbing alcohol if you have it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I don't have an answer but , I have the same problem. Sadly now it completely as stopped working .
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Phoenix 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 10
전체 시간: 2,721
