이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
It may be your cable. Assuming it is a USB/MicroUSB cable, there are some of those cables that are "charge only" and don't conduct data. I have a couple like that, and I have prominently labeled them to avoid confusion. Try a different cable, if you have one, or take it to the store and try it there. Good luck.
Russ
Russ Walden 의
