주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
548 질문 전체 보기
Screen scrambled and freezing up during bootup (no hardware issue)
When I bootup my iMac I get a scrambled screen and after a few seconds the screen freezes.
At first I thought this was a hardware issue but after reinstalling the OSX on a USB drive the OSX booted up normally. I cloned the defceted partition, reinstalled it and everything is working. The cloned one on the USB drive is still scrambled during boot.
Although I have my data there are a few programs I cannot get back so I would like to get this issue resolved. Doies anyone have any advice?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Have you tried running first aid for the disk that is causing the issues?
댓글 달기
답변 2개
선택된 답변
This machine has daughter board video card that be changed.
Here’s the part:
iMac Intel 20" EMC 2210 & 2133 Graphics Card
Here’s how to do it:
iMac Intel 20" EMC 2133 and 2210 Video Card Replacement
iMac Intel 20" EMC 2210 & 2133 Graphics Card 이미지
상품
$52.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
@mayer I stand corrected!
I looked up the P/N and I guess I put in the wrong #
Hi Mayer,
Thanks fro the reply. Same rpely as Dan's. It is not an hardware issue. See updated image on post.
Well, that's a first. Run a virus scan on the cloned drive,
댓글 달기
Screen artifacts like what your second image shows is a sign the graphics VRAM is failing. Your system uses an integrated GPU chip on the logic board with its VRAM.
Sadly you’ll need to replace the GPU board to fix this. Given the systems age and this is the last year for security support for El Capitan 10.11.x and Yosemite 10.10.x was last year. You should at least get to El Capitan. Or, think at looking for a newer system.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Hello Dan,
Thanks for replying, but it is not an hardware issue. I cloned the boot partition and reinstalled this partition (see update image of post). The reinstalled partition gives no video errors. Booting from the cloned drive produces the error.
Then you drive had an OS corruption which you have solved
댓글 달기
귀하의 답변을 추가하세요
Ratskoor 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 159
