Repair Predator FPV drone.
Started using a new Predator. Had a small hard or crash landing. Now I cannot get equal or consistent power to all blades. I’ve repeated the set up process several times but only get power to 1, 2 or 3 blades, not 4. Then, the 4th blade turns a little but not consistent. What may the problem be?
좋은 질문입니까?
if it is the same blade every time, perhaps the motor axis is bent or the blade itself is broken
Albert Zweistein 의 공유
Can I fix that and how
alexrice8384318arr 의 공유
try to spin the fourth and the third for example motors with your hand then compare the force that you applied between them.
Vertinhol 의 공유
