주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
MacBook A1278 going to sleep while working.
My macbook is going to sleep while I’m working on it. This seems to be a normal issue, but I have tried all the solutions and nothing seems to work.
After contacting Apple Support, they determined it was a hardware issue.
Hopefully someone here knows what hardware to replace so I can do it myself and save some costs.
Tried:
  • Installing new SSD with Mojave (random sleeping continues during USB installation)
  • SMC reset
  • NVRam reset
  • TRIM Enabler installed
  • Caffeine installed
  • Battery removed and reinstalled
  • Sleep sensor removed and reinstalled
Video with issue here: https://www.icloud.com/iclouddrive/0yY0H...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Your sleep sensor needs replacement, here’s the needed part TheBookYard - MacBook Pro 13" Battery Indicator/Sleep board (09-12)
Follow this IFIXIT guide to Step 4 MacBook Pro 13" Unibody Mid 2012 Logic Board Replacement Then jump down to Step 14. Now jump to Step 5 MacBook Pro 13" Unibody Mid 2012 배터리 교체. Once the Battery is removed you’ll find two screws holding the Battery checker/Hall sensor assembly on the inside sidewall behind the battery.
MacBook Pro 13" Unibody Mid 2012 배터리 이미지
안내서
난이도:
운영
5 - 15 minutes
MacBook Pro 13" Unibody Mid 2012 Logic Board 이미지
안내서
난이도:
어려움
45 minutes - 1 hour
해당 답변은 도움이 되었습니까?
점수 0
댓글 6개:
I have the 2012 model btw.
OK, you selected the wrong system this is a MacBook not a MacBook Pro!
So lets start this again from the top, I'll fix your system selection and show you the Hall sensors location. Your system is very different than this one.
@bmostrey - I've replaced my answer with the correct info. No! The part your pointing to does not have the sensor only the sleep LED.
Carefully review the new info.
Okay great! Before I buy this part, if I disconnect the sensor (step 14) would this fix my problem?
Nope ;-}
Just like driving your car with only 3 wheels when you have a flat. Sometimes you just need to make the leap of faith.
Besides this is not an expensive part, nor a difficult part to put in.
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
Bernhard Mostrey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 224
