주요 콘텐츠로 건너뛰기
질문 마감됨
Why is my mobile data not working guys?
I am using 6s plus my mobile data only works for 5 minutes and then it stops and when i toggle my airplane mode from off to on again it starts and works for 5 mins and then it stops what could be the reason please help
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
I got exactly the same issue with a 6s I had been given to repair some time back, but I have to admit that I regrettably had to decline it after some testing…it’s not a typical 6s failure and when a component gives troubles just after a certain amount of time is very hard to diagnose even with proper tools. I hope someone more knowledgeable could give some insight, but consider the time/reward ratio sometimes fights against a component level repair.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
가장 유용한 답변
you may like to check your network coverage or outages. Depending on where you are in the world you may just be unlucky enough to be in areas with poor 3g coverage. Ask friends/colleagues if they are having the same problem?
If it is not the sim, not the network coverage then it may be the antenna needs replacing
iPhone 6s Cellular Antenna Replacement
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Okay bro i ll go for antenna replacement
댓글 달기
이 답변은 원래 다른 질문의 답변입니다.
Mobile data is provided by the mobile operator with whom you have a contract, ask first.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 43
