주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Why does my camera still freeze after change
Hi!
I'm quite new to phone reparations but still wanted to give this a try.
So my problem is that the front camera didn't show any image on the phone before I replaced it with a new one. However it still doesn't show any image.
The replacement was front camera, sensor etc.
So the question remains to what the problem is.
Once again I'm quite new and would love tips and what to try and check what's wrong. iPhone 6 is the phone.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
First, I would check if your other top components work, such as the earpiece speaker. If so, the flex cable is probably okay, but there could be some pins damaged either on the flex cable itself or the logic board connector. I would disconnect the flex cable from the board, maybe spray some canned air on it, then reseat it. Either you need a flex cable replacement (whole top components), or the logic board has a short / broken pin.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I Will try and check that when I got time this weekend. Thanks for the replay for now.
댓글 달기
귀하의 답변을 추가하세요
Jack Plumeyer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 18
