주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1500 질문 전체 보기
How do I get cable 2 to seat?
I replaced the screen and digitizer but cant get the cable 2 to seat, therefore the touch feature does not work. It is a 3gs, only 6 months old, and the part is supposed to be for a 3gs. It seats fine, but will not stay. please help!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Hi Deb, are you confident the part is for 3GS? The 3GS has a black plastic piece between the metal contacts. You may have to look at some pictures to compare. If this is confirmed and the connector just won't snap into place, you need to make sure there is nothing on either connector that is in the way. Once you have the connector aligned to the one on the board, you press down. One side may go down easier than the other - press with a little force. If this does not work, don't keep forcing it - you can damage the fpc connector on the board. Patience, a couple deep breaths, and a steady hand - you will get it! I hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had the same issue as you. I thought cable 2 was OK but it kept popping off. I finally concluded I wasn't applying enough pressure. Once I did it stayed connected. I'm assuming you have the cable correctly aligned. Check that before applying more pressure. Good Luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
deb 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 710
