주요 콘텐츠로 건너뛰기
Apple은 MacBook Air 13"를 2017년 6월에 새로운 Broadwell Intel Core i5 프로세서로 업데이트하여 성능과 배터리 수명을 약간 향상시켰습니다.
423 질문 전체 보기
Spilled a tea on my MacBook keyboard
Hi,
I’ve spilled a tea (no sugar, no milk) on my Mac keyboard. It was 1/3 of 0,4l glass, so not that much. Also, the tea is not that acidic, is it? I immeditally plugged everything off and switched the device off. Then I left it upside down for 24hrs to dry it out and to let the water eventually come out. After that, I took the Mac to the closest Apple store. They did run a diagnosis test and no issue was found, everything just works fine.. However, I was advice to make a repair of a top case with keybord and trackpad - the cost is £300. I have a deadline for my Masters dissertation in two weeks and need to use the laptop.
Could anyone please tell me if I can use it when the diagnostic test has not found any issue? Is there any chance that I’m just a lucky guy and the laptop passed with no damage?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
exact same here, what happened and what did you do? what do you advice me?
댓글 달기
답변 1개
선택된 답변
your better having the logic board cleaned and the keyboard changed as a precaution. corrosion will happen overtime and just because its still working atm doesnt mean it won’t stop working at some point due to the liquid damage
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
This is the correct answer.
댓글 달기
귀하의 답변을 추가하세요
Patrik Huber 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 2,392
