주요 콘텐츠로 건너뛰기
2012년 10월 23일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Apple Fusion 드라이브.
208 질문 전체 보기
Can I create a bootable macOS USB drive in Windows or Linux?
Hi, I would like to be able to create a bootable macOS USB flash drive, but it seems that the only official way is to use a Mac. I don’t have a Mac, so is there a way to create a bootable USB macOS drive in Windows or Linux that doesn’t involve hacked ISOs and whatnot?
Please note: I had to select a machine for this question, so I just selected a 2012 Mac Mini.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Most Mac’s offer internet recovery which allows you to install the MacOS from the net How to Re-Install OS X with Internet Recovery on a Mac
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Ok, I’ve found the answer. If you have a Install macOS Mojave.app file, which I got from somebody else’s supported machine, you can flash the /Contents/SharedSupport/BaseSystem.dmg to a USB drive with a tool like Etcher. The only catch is that this is a recovery partition image, so you the bootable USB will download a copy of macOS from Apple’s servers, but at least it offers the option for machines that don’t support internet recovery, because I don’t own a Mac.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Hi Rupertus,
did you check this ?
https://hackintoshpro.com/bootable-usb-m...
Rob
If you have a 2012 Mac mini you don't need to go to such lengths it has internet recovery which will allow you to create a bootable drive (internal or external).
Reference: How to Start up Your Mac in Internet Recovery Mode
Then once you have a bootable drive you can then download the OS installer from the Apps Store. You can even create a OS installer to setup other systems How to create a bootable macOS Sierra installer drive
댓글 달기
It is possible you can get a app for windows called Trans Mac keep in mind that you need the OS X file also you need a 8gb drive or more and it should do all the work. You just have to select format disk for mac then once your done with that select restore disk image then go find the OS X image on your pc then it should do all the work for you.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Rupertus 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 28
전체 시간: 7,225
