주요 콘텐츠로 건너뛰기
2016년 11월에 처음 출시된 3세대 Samsung Gear 스마트워치 입니다. Tizen OS를 실행하는 원형 OLED 디스플레이가 특징입니다.
Anyone having trouble removing the tri-point screws?
I have the Pro Tech Toolkit and have tried using all the tri-points included (Y000, Y00 and Y0), but none seem to be grabbing the screw properly. The tear-down indicate that the Y00 should do the trick, but it seems like the tip is too pointy and is floating above the grooves. Anyone have the same issues or have any tips?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 4개
this is typ[cal of screws made in Japan, etc. they have a flat bottom. Just take a file and flatten the tip of the screwdriver and then the screwdriver will grip the screw correctly.
Thanks didn't expect it would work but it does
Thanks, #2. I also was not expecting it would work. I bought a high-quality bit set (at least looks and costs like; brand Protech). There are 4 Y bits in this set, here listed from the smallest to the biggest: Y0.6, Y2, Y2.5 and Y1 (weird, no?). I gently filed the tip of the bit Y2 and it worked wonders.
Wow! Thank you so much for the tip, saved me some time and money tracking down a decent tri-point when I wouldve run into the same issue
댓글 달기
답변 1개
가장 유용한 답변
No, I’ve removed them without problem with a Y00 tip (one of them will fit and do the job, 0, 00 or 000). This was on a Samsung Galaxy Gear S3 Frontier.
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
@benjamen50 my screw look more like the Torx Tri-Lobed/Torx 3-Lobed screw om this page. https://thepeople.co.ke/1150/best-tri-wi...
Did yours look the same?
I just tried it (Didn't seem to require much force) on my Samsung Galaxy Gear S3 Frontier which I'm using now that I bought a few weeks ago with the Y00 screw bit that came with my iFixit Pro Tech Tool kit and it came out without any issues.
It's the latest revision of the tool kit so if you bought the tool kit a few months ago or newer it'll be the same tip.
It is indeed the Lobed Tip which is the one I just tried.
So I was using a Y0, and Y00 bit from another kit I found at Walmart (HyperTough) and had the same issue "catching" the screw as you did.
After looking at the iFixIt picture I realized theirs Y bits are flat, while the Walmart bits are point. preventing it from catching. I'll have to buy another tool bit to get it to work but if your bit was pointy like mines were, it will never catch.
I too tried to open the back cover of my samsung gear S3 classic with a tripoint Y00. It did'nt work. Perhaps i will have to get a triwing Y00 screwdriver. Most of the online sites do not differentiate between triwing and tripoint.
댓글 달기
답변을 추가하세요
Greg 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 46
전체 시간: 7,393
