주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2265 질문 전체 보기
iPhone 7 stuck in boot, still after dfu? works for an hour after
Hello, I had an iphone 7 at my store yesterday.. the phone showed apple logo then turns off and apple logo appears again. I put the phone in recovery and updated via itunes. it was complete and I got to the lock screen typed in password. then everything seemed to work as it should. Today they came back, phone was back in boot loop. I put it back in recovery mode and itunes resat the phone back to “new”.
Now about 2 hours later they called and its the same issue even tho I was playing on the phone for about 30 minutes before calling them saying everything was fine.
Anyone know or has an solution to what the issue could be?
I did try with a new battery as well, same issue.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
i have n issue right now that a 7p boot loops after a screen replacement but if i unplug front camera flex it boots normally and stays on, if i plug in cam flex with phone on it works for 2 mins then starts boot looping, not sure this is any relevance to your issue but try running with front cam unplugged and see what happpens
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
That is an different issue. all you need to do is to replace the facetime-flex its because the iphone 7 plus facetime flex is really sensitive being pulled of the old screen
I might test it tho. it was never a screen repair or anything has been repaired on the device. it only came to my store because of boot loop issues,.
댓글 달기
귀하의 답변을 추가하세요
nicolay.94 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 5
전체 시간: 49
