Cube is leaking from the bottom of the unit any suggestions?
The unit in itself still works cooling/heating but it is now leaking from the bottom of the unit doesnt appear to be at the connect hose
좋은 질문입니까?
좋은 질문입니까?
I would suspect the hose connections as seen in step#5 of this teardown:
ChiliTechnology ChiliCube Teardown
To test use a small artist type brush and use a dishwashing soap and paint it around the connectors. If you get bubbles, you have found where the problem is.
이 답변이 도움이 되었나요?
Once you find the leak, how do you fix it?
Seal the crack with a good product like this:
I had to replace one of my Ooler hoses, they look to be food grade silicone. Easily bought at amazon but you have to figure out the size. I used aquarium tubbing to test, the silicone will be in soon.
지난 24시간: 0
지난 7일: 2
지난 30일: 21
전체 시간: 6,880
