주요 콘텐츠로 건너뛰기
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
61 질문 전체 보기
Can I use the glass and battery from a mini 2 on a mini 1
I recently found a iPad mini 1 in a recycling center. The battery is a bit bloated and the glass is cracked. Can I use the glass and battery from a mini 2 to fix the mini 1? I dont need the LCD just the glass. Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hi Ethan, yes you can, the IC chip is the same one from the iPad Mini 1. Therefore, you can use the glass. However, the battery is not compatible.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ethan Leroux 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 20
전체 시간: 335
