주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
Lighting jack is not working
My iPad Air 2 is not charging. I’ve tried restarting the device, cleaning out the lighting port, changing cords, chargers, and wall outlets to no avail. I was looking for other ideas as tot he cause, or for a replacement part to replace the defective part.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
Thank you all for the info. Much appreciated!
댓글 달기
답변 2개
Unfortunately, your port may be defective. It is soldered to the Logic Board and would require micro-soldering to be replaced. If you want to repair it, it may be cheaper to take it to Apple, as micro-soldering can be very expensive.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You can buy a replacement charging dock voor the ipad air 2 it isnt that hard to repair no soldering needed , buy one with flex cable.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
The charging port flex assembly is connected via soldering to the logic board. So it will require soldering to replace that charging port.
Good video on how it's done here: https://www.youtube.com/watch?v=IdyIQYrO...
Alec and Ben , sorry you are right. For the normal ipad 2 it is easier and with a flex cable.
댓글 달기
답변을 추가하세요
Ryan Lantz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 29
전체 시간: 428
