주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
265 질문 전체 보기
Battery Doesn't Calibrate After Replacement
As in the title, this doesn’t seem to work, according to coconutBattery the full charge capacity is 4752mAh, and the design capacity is @ 72% of 6600mAh. BUT it lasts for hours from 7% charge, goes down pretty quickly before that however.
I’ve tried:
  • Charge until full, then 2hrs more, then completely deplete and leave for at least 5hrs in sleep mode. Then recharge to full - which I left charging for over 12hrs. No change
  • After this I reset the SMC and tried the same procedure, still no change in it.
Any possible solutions ? Could be a faulty SMC perhaps ? I did see some sticky gunk inside when changing the battery, looks like something was probably spilt on it at some point..
*Edit* coconutBattery Screenshots:
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Can you post the CoconutBattery main window with the MagSafe connected and again with it disconnected 기존 질문에 이미지 추가하기
Added, thanks
댓글 달기
답변 1개
가장 유용한 답변
Not good ;-{ Your charging logic has a problem on the main logic board or the DC-In board.
If you look at your captures you’ll see the ‘Charging with’ line is showing charging when the MagSafe adapter is disconnected! For reference here’s my MacBook Pro’s:
As you can see mine is reporting a discharging condition.
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
Hrmm, maybe I screenshotted too quickly, looking at it now it says 'Discharging with.. I'll add another screenshot to the question.
That’s much better!
Who’s battery is this?
I bought the pack from iFixit, so it's their battery I guess
You'll need to get a replacement from the IFIXIT Store
댓글 달기
귀하의 답변을 추가하세요
Javier Romero 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 132
