주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz), 2.5 GHz (Turbo Boost 최대 3.7GHz) 쿼드-코어 Intel Core i7 프로세서.
Why does my new logic board only accept OS X Yosemite?
My hard drive uses the MacOS Journaled format.
I put in a new logic board and every time I try to install High Sierra from a USB key , the installation goes as planned until it reboots.
The problem is that the computer keeps rebooting indefinitely after a minute or so.
I used internet recovery and it downloaded Yosemite (!).
I guess it’s a matter of firmware, isn’t it?
But it seems the only way to update the firmware is to install High Sierra, which the logic board doesn’t let me do.
Is there a way I can solve this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Depending on what you had on your system before as well as how you enabled OS recovery you will get the original OS the system had. Pressing Option & and the R keys will get you the highest your system will support
Review this T/N Mac startup key combinations and this T/N How to reinstall macOS from macOS Recovery
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Hi there, thanks for your response. I tried the Option+Command+R but since Sierra was never installed on it, this command doesn't behave the same way.
I still can't boot up, even under Yosemite. It keeps rebooting after a few seconds.
Could it be because there is no battery connected to the logic board?
Or maybe I didn't connect some cable correctly to the logic board?
Yes, you need to have all the pieces installed and a working battery ;-}
@danj If the High Sierra install put the APFS format on it, it may not accept a lower system.
댓글 달기
답변을 추가하세요
Alex222 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 132
