My right click is stopped working.
I was using it casually when I pressed the button and it didn’t work and it didn’t click.
좋은 질문 입니까?
좋은 질문 입니까?
On 99% it’s microswitch. U can replace it .
Find this on your region
https://www.amazon.co.uk/Mouse-Switch-Mi...
U have help here on this website
해당 답변은 도움이 되었습니까?
Had you tried pressing on other buttons?
Had you test on another PC?
If you press and use a little force, does it works?
If it is under warranty, suggest you to send in for service.
Else….
you need to open up and try replacing the micro switch first.
해당 답변은 도움이 되었습니까?
I just bought 3 switches off of Ebay and replaced the right click myself. It just took some solder and a solder pen.
24 시간 전: 2
7일 전: 25
30일 전: 87
전체 시간: 5,970
댓글 2개
Hello, I have the same issue with the MX Anywhere 2 version, not the 2s. Would you happen to know what micro switches are used in the 2 version? I want to replace them but there is no info online about the type of switches used in this mouse.
Kindest Regards,
Rodrigo Solis
Rodrigo Solis 의
So I have the same mouse the MX Anywhere 2, and I opened it up and looked at the numbers on the switches and just ordered them on Ebay. To save you save you some time here is the Switch name and a ebay link.
Omron D2FC-F-7N(10M)
https://www.ebay.com/itm/5PCS-OMRON-Mous...
Maxthegamer4548 의
