주요 콘텐츠로 건너뛰기
Repair guides and support for electric and stove-top kettles.
54 질문 전체 보기
The handle falls over
I have a 40 year old Asta stove top tea kettle and the handle falls over, so the wooden part of the handle ends up in the fire. The screws that attach the handle have been tightened, but what looked like rubber washers have broken down with age. What would be able to withstand the heat from a gas burner to replace the “washers” ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
Silicone is significantly more resistant to heat than rubber.
Thanks! Will try to track some down
Thanks to you both!
댓글 달기
답변 1개
가장 유용한 답변
Here is a chart to help you determine the inside diameter of washers:
https://www.engineering.com/Library/Arti...
The get a fibre or nylon washer set.
https://wbpartsexpress.com/5610-277-62?p...
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
귀하의 답변을 추가하세요
MM Harvey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 278
