주요 콘텐츠로 건너뛰기
Nintendo Switch/닌텐도 스위치는 도킹 스테이션을 통해 TV에서 플레이하거나 이동 중에도 플레이할 수 있는 휴대용 게임 콘솔입니다. 2017년 3월 3일 출시되었습니다.
Nintendo switch is charging insanely slow
I am having a problem with my switch and I was wondering if there's a chance you guys could be of assistance at all.
So I have a nintendo switch that is giving me some issues. It's never been used on any 3rd party dock or chargers, only the official supplied chargers. I hadn't played it for about a day or so, and when I came back and tried to turn it on it was dead. When I plugged it in it would show the battery symbol, but never charge up enough to get it to boot. I googled around for about an hour and tried everything possible with no success.
I then booted the switch into RCM mode and was able to boot to Hekate. Through hekate I can see that the battery capacity is 100% of the original capacity, but the current capacity is somewhere around 3%. From there I tried a battery fix tool that is built into Hekate, that did not solve the problem. After that, I rebooted the console through Hekate. This time, to my surprise, it actually booted all the way through. My profile loaded up and everything came back. The problem now is that the switch still is not charging. The device will stay on, but it is currently stuck at 2%. If I turn the device off and leave it charging it will now charge incredibly slow, and eventually deplete again when turned on. The good news is that the device will now turn on if left on the charger for an hour or two.
I have a few years of experience repairing electronics and soldering devices, so I figured I would open it up and take a look. I did a lot of googling and gathered all the info I could, and then went to work. The charge port seems to be working fine, currently the switch is pulling .47A at 4.97V. I am checking this using a little dongle and a 3rd party cable. As far as I can find, this means that the device is charging correctly. When I check pin 5 on M92T36 I get 3.29V. According to a few people on the internet (which may or may not be accurate), this means that M92T36 is not the problem. I believe this is one of the most common problems with the switch right now, so I was surprised to see that it is (again, I could be wrong) working fine. From here, I tested BQ24193. On both VBUS pins (1 and 24) I am getting 4.8V, and as far as I can tell this means that power is getting to the chip. All of these readings are while the device is plugged in. After this, I turned off the device while it was plugged in and left it for around 30 minutes. I then booted back into Hekate, it told me that the battery was at 10%. So the console is getting power, but it's charging very slowly.
I just tested the battery to make sure that was working as well. While plugged into the system (the battery, the charge cord is unplugged) I'm getting 3.5V from both of the positive power lines. With the battery unplugged I'm still getting 3.5V from each positive power line. The battery says it has a 3.7V output, so this is close enough. I believe the battery is fine based on these measurements.
With all of that said, is there any chance you guys could provide any assistance to me? If I could be pointed in the right direction I could keep trying to figure it out, but at the moment I'm stuck. I can't seem to find any more info as far as what I need to check to see if everything is receiving the correct amount of power. From what I can find everything is testing fine, so there must be something that I need to check that I can't find any info on. If you guys could provide me with any info that would be amazing.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 5개
so, i used a usb-c hp probook charger (65w) to try and charge a switch, but it wouldn't turn on! Then i smelled it! there was this HORRIBLE burning plastic smell, and after that it wont charge even with a normal usb-c, in fact my friend's cord apparently is now totally shot! however, if i were to charge it slower, with a cord that's power is severely reduced, could it charge, albeit VERY slowly?
i have the same probelem but for no reason instead. i use an onn. usb-c charger, have three of them. none of them work right so i just decided to leave it
Having same problem. I tested my soldering skills by changing the usb port. Port works but still same problem. Charges super slow. So most likely the chip now. Gonna try that now
To charge faster, use the charger that came with the console.
This was happening to me and when I came home from work I saw that my switch wasn't done charging and I was a little bit mad Abt it
댓글 달기
답변 5개
선택된 해법
How long did you leave it charging? Switches will slow charge (around .40-.47 or so) for a long time sometimes. I've seen them slow charge for hours. That's what I would try first...just leave it charging overnight.
이 답변이 도움이 되었나요?
점수 6
댓글 5개:
Had one last weekend and that fixed it, now the next charge was "normal" under couple hours, while the first one took about 8 hours to fully charge.
Ya, I've had some take an extremely long time.
My switch has been charging for 24 hours and only went up by 30%, not to mention it was at 5% when I started.
Mine takes at least overnight and sometimes two days to charge. It charges too slowly to play it while it’s charging.
I’ve pretty much stopped using it for these reasons.
My switch is taking a bow on an hour and it only charges up to 10% basically or sometimes it charges only 10% when it has been charged for 3 hours
댓글 달기
I have had luck in the past with replacing the battery in this exact situation, although sometimes even a battery doesn’t seem to work. These power issues are super common on the Switch and it sounds like you’ve ruled out the other most likely causes (the USB-C port and the charging ICs). If a new battery doesn’t work try asking @tronicsfix if he has come across anything new. Good luck!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
My son’s switch had a black screen after sitting idle for a month while he was away during summer break. It would not take a charge, or so it seemed, but the LCD light turned on and off when we docked the console.
I checked all the obvious solutions and read solutions to the above posted question. Then followed the link to Nintendo’s website hoping to read about a recall all to no avail.
Fortunately, I read an article about the “console not charging, a black screen and won’t wake up from sleep mode”. D’uh
It froze in sleep mode, the battery died and a proper reboot solved the problem. Which is holding down the power button for 12 seconds along with a couple other omfg that’s so simple solutions! And then I’m the ifixit goddess until I explained the problem and hard restart solution
See for your self…
https://en-americas-support.nintendo.com...
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
It took an hour to charge 😒
댓글 달기
it is normal it is because I have a brand new switch I got it like 1 day ago and it still charges slow because the battery is very big and things like those batteries need more energy then normal batteries example big batteries takes up more energy then normal sized batteries while on the other hand normal sized batteries takes less of the energy then a big sized batteries it takes less time to charge than big batteries.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
shut the &&^& up
댓글 달기
Well my switch is on charge and it took over an hour to charge the screen was black with a battery in the corner but it would not go up
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Andrew Guerrero 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 43
지난 7일: 236
지난 30일: 1,154
전체 시간: 119,750
