주요 콘텐츠로 건너뛰기
Apple의 2016년 개정판 노트북은 전문 사용자를 대상으로 제작되었습니다. 15 인치, 2880 x 1800 Retina 화면, 쿼드-코어 Intel Core i7, 256 GB / 512 GB / 1 TB / 2 TB 저장 공간 옵션, 16 GB RAM, 그리고 Touch Bar가 장착 된 키보드가 특징입니다. 2016년 11월 출시되었습니다. 모델 A1707.
260 질문 전체 보기
Cracked MacBook Pro 15 bottom bezel
I crakced my macbook pro’s bottom bezel, first day display was fine.. now a black strip appear..when tap on that cracked portion. That area color is reverting the color of actual screen..
So costly to replace entire screen.. please help..
Update (01/12/2019)
Is it possible to change chin plate? When clicking there color is inverting with black color when tap on that cracked portion. That area color is reverting the color of actual screen.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Same thing happened to me.. so gutting. Happened within months of getting the device. Can’t afford to repair it
댓글 달기
답변 2개
Review this guide: MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement. You’ll need to order the plate from eBay Front Glass Bezel LCD Logo Cover Trim MacBook Pro 15"
Update (01/12/2019)
OK, Thats not good ;-{
The chin plate covers the edge of the LDC panel’s fragile contacts. Your LCD panel is also damaged! You can’t do anything to fix it other than replace it. Unlike the older models this series as the T-CON board mounted in the main case so more lines are needed to move data from the case to the lid as you can see here:
You have no choice here you need a new display assembly MacBook Pro 15" Retina (Late 2016-2017) Display Assembly Apple P/N 661-08031
MacBook Pro 15" Retina (Late 2016-2017) Display Assembly 이미지
상품
$507.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
Does it will help to get my display back to normal? I mean that black area..
OK, thats a different issue! This only addresses the chin plate damage.
So your screen has an issue too! Post a picture or two here for us to see 기존 질문에 이미지 추가하기
If the bezel i cracket, will it interfiere with the brigtness of the display or colors? Im thinking og byeing at mac with a crackey bezel.
@Lars Ulmer - It could! The ribbon cables are just behind the plate so they could become damaged. Review the images in this guide MacBook Pro 15" Touch Bar 2017 Replace LOGO Baffle on the screen,替换屏幕底部LOGO挡板 Replacement
댓글 달기
There are ribbon cables connected to the screen that hide behind that small chin bezel. When you smashed the bezel in you must have hit one of those cables…
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
max wright 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 8,973
