주요 콘텐츠로 건너뛰기
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
577 질문 전체 보기
Ipad keeps shutting off when sufficiently charged
Hi,
I just recently completed a front panel replacement using the iFixit guide. However, after using the iPad for 10-15 minutes, the app I would be using crash and the iPad showed a low battery icon with the lightning cable. When I went to go charge the iPad it booted up. This all happened when the iPad was at 78%. I assume there’s is something wrong with the battery connector but not sure how to fix it.
Thanks, Ron.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
batteries are touchy, they need full power cycles to keep and maintain healthy , the more random the charges are the more inconsistent the cells become
댓글 달기
답변 3개
선택된 답변
battery capacity is bad. time to get it replaced. your local repair shop should be able to or apple of course, also if you can do it yourself that’s possible. But its for sure your battery
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
So it has nothing to do with the battery connector then?
not typically. if you plug it in and it shows the lighting icon it is reading it. but you also have an iPad that's 5 years old or so. lithium ion polymer typically starts degrading after a year and a half
댓글 달기
My iPad would shut down & need restarted 4-6 times whenever it was charged to 100%. Finally saw a fix online that worked. Let the battery drain completely, then charge it to 100%. Worked for me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Battery. Battery. ..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ronald 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 63
전체 시간: 17,083
