주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
iPhone 3GS bricked ;(
I went to go jailbreak and unlock my iPhone 3GS and I checked the box beside iPad baseband and told me that i can’t restore with stock ipsw, and I was ok with that so i clicked ok and it popped up with the iPad baseband is not compatible with iPhone units manufactured week 35 of 2011 or later. if this is an iPhone and if digits 3-5 of its serial number are "135" or later (xx135...), then you should NOT proceed! and mine was 145 and i proceeded anyways like an idiot and at the end the WI-FI tab said no WI-FI, and their was no Bluetooth, and no IMEI, no ICCID, and no Modem Firmware. please help, i cant find out how to fix it. PLeASE HeLP!!!???
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Your description says your IMEI is xx145xxxxxxxxxx (which is good). I assume you read the iPhoneHacks article. It says there that if your IMEI is xx135xxxxxxxxxx, you should not install the iPad baseband. But in this case, the iPad baseband's side effect may be remediated.
The latest redsn0w application (version 0.9.15 beta 3) gives you an option to downgrade from iPad baseband under the Jailbreak section. Assuming you currently have iPad baseband installed (06.15.00), you should tick the box "Downgrade from iPad baseband" then proceed with the normal jailbreak operation (Uncheck everything but Downgrade). If it gives an error, go to Extras then select "Browse" and point the file to a stock IPSW. Redo the steps above and this will fix your baseband issue.
If the first solution didn't work, try booting the phone in DFU (or pwned DFU if it failed). iTunes will then tell you that it detected an iPhone in recovery mode. Perform a normal Restore and this may fix the issue.
To check if the downgrade was successful, your baseband should show 05.13.04 (or any but not 06.15.00).
Let me know if it works :)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jerret Burton 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 19
전체 시간: 371
