주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Phone died and wont turn on/charge
Yesterday my phone died and now it wont turn back on or charge, it only shows the red battery symbol but no apple logo. I tried charging it for 4 hours but no apple logo, I tried cleaning the battery port, plugging it into different cables, the itunes-pc method and even the heat/blow dryer method but it doesn’t want to work. What should I do now? Should I got get the battery changed?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
I recommend getting the battery changed. It sounds like the battery has gone faulty.
Just to confirm when you plug in the charger it does show a battery logo without the charging plug cable icon at the bottom right?
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Yes, it just shows the low battery logo. That does mean it's charging right?
Yep, it means that it is trying to charge the battery.
I agree with Ben, the first step here is to try a good quality replacement battery.
Good advice about a battery replacement. Common issues with a bad battery are rapidly reducing percentage, sluggish performance and random switching off with a red battery symbol like you have.
댓글 달기
귀하의 답변을 추가하세요
Tin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 58
