주요 콘텐츠로 건너뛰기
Third generation Surface Pro tablet, released June 20, 2014.
122 질문 전체 보기
How to test the battery pack before replacing it?
I have a dead Surface Pro3, presumably with a defective battery pack. After many months of looking at it I took the plunge, broke through the screen and have the battery tail with its connector free. The main connector tabs show zero volts but Im not sure if this indicated a dead cell or that I am not enabling a switch within the battery management scheme which is part of the battery pack.
Can anyone tell me if the battery tail should be at 7.5V standalone, ie how do I test the battery pack before trying to replace it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
In Windows 10 you can open a command prompt with admin priv and type powercfg /batteryreport /output "C:\battery_report.html
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
no directly replace it, without doing any test, as you already said the battery is dead so there is no reason to test it, a dead battery could also harm your surface pc , so be cautious.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tom Nicols 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 56
