주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
MSI GS63VR 7RF Stealth Pro는 2017년 MSI에서 출시한 게이밍 노트북입니다. 이 페이지에는 GS63VR 7RF-252US-BB7770H16G1T0DX10MH 모델에 대한 수리 안내서가 포함되어 있습니다. 모델 번호: MS-16K2.
replacing thermal paste and cleaning fans?
I am planning on purchasing this laptop from a friend, and it hasn’t been used heavily although I do want to clean the fans and if necessary replace thermal paste cause idk how long it’s been used for, how many steps would that take compared to most everything else here?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
The fans will be relatively easy because they’re right behind the back panel. As for the heatsink, you will have pull out the motherboard, which can be a little tricky since you might have to pull out other parts, but if you keep good notes, and take pictures, you should have no issues.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
It is doable, but will take about an hour. make sure you have isopropyl alcohol, good thermal paste and lube for the fans. Be very careful with the insane amount of ribbon cables.
May I suggest iFixit tool kit as some of the factory screws are pretty snug and you will need the exact size screw driver not to strip them. I actually had to replace two of the screws because they got stripped. While doing the cleaning I also upgraded to 32GB 3200 RAM. The performance boost is definitely noticeable and the laptop runs about 5-6C cooler.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Erick Balanzar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 1,882
