주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
iPhone 6s will not turn on
Hi, I have got a mate’s 6s that I am trying to fix… the phone will not power on full stop. Regardless of whether it is on charge or not! Also, a computer cannot pick it up, even a third party piece of software. I have replaced the lightning port as my first step but seems to have not worked, although I will try plugging it in to a computer to try for a response.
Is it worth trying to replace the battery or is it most likely a board issue? If so, is there anywhere in the UK that you guys reccommend for board repair or am I better off buying a second hand logic board and replacing it?
When replacing a logic board, I can put any board in right? As long as I have the associated touchid sensor?
Thanks,
Ed
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Your 6S should be giving signs of life, but in case you might have a faulty screen and a faulty battery you wouldn’t get signs of life from a Pc nor see anything from the screen. Hard to tell without testing and/or trying known good parts. You would need an Usb Ammeter to check if the iphone at least draws some power to start with, but on the other end you risk buying parts and tools without getting anywhere. With current prices for used 6s iphones is really hard to tell what’s the best way to spend your money, but in case you decide to buy a used board there’s no problem about the memory size, all boards fit the same.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
this could be an issue with the charging ic or a vcc main fault. Theres probably a few techs on here from the uk, im based in northern ireland
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
That’s what I had thought... just wonder whether it’s worth having it repaired (it’s a 64gb board) or buying a new board?
it all depends if the board is repairable. i do a no fix no fee and usually charge around £30 if its repaired
댓글 달기
귀하의 답변을 추가하세요
Ed Beckett 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 104
