주요 콘텐츠로 건너뛰기
A 15.4" Windows XP laptop released by Dell in 2006
11 질문 전체 보기
phoenix bios password no resetting
I like to work on old laptops, so I have a dell inspiron 1501 , it wonrt boot windows so im trying to go to phoenixbios setup utility but it says enter password when I enter 3 wrong passwords it says “09252” I look up online for answers and follow a instruction to remove the bios battery for 15-30 minutes then put it back in I did this twice bu the bios password is still there , also i unplugged and removed the main battery before i followed these instructions
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 3개
선택된 답변
Hi @fegelein3290
Try this https://bios-pw.org/
해당 답변은 도움이 되었습니까?
점수 7
댓글 4개:
thanks i will try this thank you
ill make sure to update this later
thanky you augustine it worked perfectly
It doesn't work on my laptop
댓글 달기
Removing the BIOS battery won’t clear the password on any computer built since the early 2000’s at least since all the BIOS settings are held in flash memory (similar to a USB memory stick) rather than in battery-backed CMOS memory. The battery only powers the real time clock, which will probably revert to Jan 1st in the year of manufacture.
You will have to hunt around, but it’s likely there are 2 distinctive solder pads on the motherboard, maybe triangular and/or with some distinctive marking against them and hopefully visible when you remove a service cover from the base of the laptop. You have to short these together whilst pressing the power-on button, maybe for a minimum length of time, or some such protocol.
But it can be tricky, not only to get the sequence right but also to hold the pads shorted whilst pressing the power button. It’s much easier if you solder a pair of flying leads with a push-button switch on the end to the pads.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
flying leads
flying leads?
댓글 달기
https://www.askvg.com/how-to-reset-remov...
go to that website!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brayden S 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 26
30일 전: 114
전체 시간: 19,408
