주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz), 2.5 GHz (Turbo Boost 최대 3.7GHz) 쿼드-코어 Intel Core i7 프로세서.
774 질문 전체 보기
SMC error after battery change
I changed my dying battery with one from ifixit. After putting in the new battery I reset the PRAM and SMC and turned the laptop on. From then on, the fans blew at full power constantly and kernel task was crippling the CPU. Diagnostics showed error PFM007 - there may be an issue with the SMC. The old battery was destroyed during removal, so I couldn’t try putting it back in. I was sent a new battery from ifixit, but the problem persisted. SMC and PRAM were reset numerous times, nothing changed. I installed istats to see if anything looked out of the ordinary, everything looked fine except missing temperature data from the palm rest.
So my questions are - is it possible to reflash the SMC to an earlier firmware to see if the problem persists;
and can the palm rest temperature sensor be causing these issues, and where is it located (I read somewhere that it’s part of the trackpad ribbon cable)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
I’m suspecting you damaged the trackpad cable MacBook Pro 15" Retina (Mid 2015) Trackpad Cable or the trackpad its self MacBook Pro 15" Retina (Mid 2015) Trackpad which is where the palm sensor is located.
Apple doesn’t tell us what the discreet PFM007 error means other than it’s an SMC error.
MacBook Pro 15" Retina (Mid 2015) Trackpad 이미지
상품
$29.99
MacBook Pro 15" Retina (Mid 2015) Trackpad Cable 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
i got a new cable but the problem persists, im going to try the trackpad then. thanks
댓글 달기
가장 유용한 답변
i think the fans running at full speed can be caused by a broken palm rest temperature sensor. as far as i know, when the system detects one of the temperature sensors doesn't work, it makes the fans run full speed (that's at least what happened with my iMac when i broke the hard drive temperature sensor. You might've either damaged the sensor or the cable during the removal of the old battery. I don't know how to replace that palm rest sensor though.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I hav the exact same problem with my MacBook Pro mid 2015 after ifixit battery replacement, did you find the solution for the fan and CPU issues?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
T Tomov 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 870
