주요 콘텐츠로 건너뛰기
Repair guides and support for your Toshiba TV.
Toshiba LED 3D tv 46TL968 issue
Hello my tv is about 5-6 years old and problem is when i switch tv on its alright for about 2-3 hours then switch off but sound on then when i switch back on its alright for about 30 min, then the same switch off and on, and then he off after 5min then after 1min then 15s but if i keep him off for a while is working longer for me its looks something overheats but im not sure i think to buy new power board but not sure its power board maybe someone has same issue on this tv or similar toshiba tv thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
It overheating…..Take the back off. use a can of compressed air and a soft paint brush and carefully clean and blow the bust build up off the circuit boards ,,,clean air vents on back panel.. Nake sure it has good air flow…Bust is a real killer to electronics.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
thanks to your answer i just cleaned everything yesterday but after 4 hours its starts switching off and when i back on its starts off every 30min 15min 5min...
댓글 달기
I add some pictures also on stand by tv back lights i not bright but always stays on also led driver board makes buzzing sound when on when back light off it stops.
on images is back light voltage its when is on
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I was worried about that.. Those high end graphic cards generate a lot of heat.. Let me ask this… was there a lot of dust on these boards. That's really a rhetorical question. HP built a laptop, the dv 9000. with a high end graphic embedded in the board with a hot running AMD processor///fast, powerful…after about 2 years in service they stated failing by the thousands…By then most of them was out of warrant and the cause was discovered.. excessive dust build up blocking air flow thought the heat sink… HP made a half-heated effort to correct it but they where convinced with the disclaimers issued and disregarded. it was there problem, and they where right. A class action law suit was file and every one jumped on board for the ride…this would have dragged on for years but HP, in the interest of keeping good relationship with future customs, settled. Bottom line is…a little bit of horse sense or common sense, will take you a long ways in this World. Im a Retired A.S.E Master Certified automotive Tech and 90 % of what I did was just common sense. Never went to school one day for it and I had to make my own mistakes Right there in the repair shop.. Those Toshiba LED 3D tv 46TL968 went though a similar law suit at the tune of a 300 million dollar settlement but it was for the led screen and it was the 36 inch. I pulled one out of the trash about 6 years ago with a cracked screen. Took the components out sold them on eBay for close to 400 dollars..
Do you have the specs on voltage input and output. Ill pull up the test diagnostics and research for replacement boards for you.. Those are excellent boards but like I said…..Dust is the number one killer on electronics.. I have a HP g7 pavilion I got new in 2010 with window 7. I still have it. It runs windows 10 enterprise. stills runs great. All because I keep it clean. I maintain the system .. And I have been hard on it. Ive crashed this computer many times. 300 times at the least.. Give me a day or two. That's a good tv I wouldn't trash it..
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ricardas Ribakovas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 564
