이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Disconnect the cable, check the cable and motherboard ends for damage, reconnect and try again. If it still fails, reconnect your damaged digitizer (assuming it still worked, at least partially) and see if the phone is still not responsive to touch. If it works with the old and not the new, you've got a bad replacement part.
Steve 의
