Why is the battery only charging halfway?
I have replaced the LCD degitizer screen with new and after that power button does not work anymore and only charging halfway and also quickly drains power. Can someone help whats wrong?
좋은 질문 입니까?
좋은 질문 입니까?
The power button failure MIGHT be the result of a bad connection to the motherboard. The connector in question is here:
https://d3nevzfk7ii3be.cloudfront.net/ig...
However, given your power button issue + the lack of full charging + fast power drain (+ excessive heat, which I'd bet your phone is also showing), I'd put my money on a failure of the Tristar (U2) charging chip, which requires microsoldering skills to repair. Even if the power button failure is not the result of the Tristar chip, the rest most certainly is.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 509
May be unsecured cable connections?
Eiji Uehara 의
